New Rims....
Discussion in 'Exterior' started by .ScRuMpTiOuS., Mar 24, 2011.
  1. .ScRuMpTiOuS.
    .ScRuMpTiOuS. Full Access Member
    Houston, TX
    They're Enkei RT6 - 18x8.5...
    I want to paint them black, what do you think?
    I have a stock height 4x4 CrewCab, if I get some 315/70/18 BFGs or Terra Grapplers will my tires rub?
    Will I need to get different gears?
    TIA.
  2. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    No to the gears but if you change the gears you will get better mpg not sure which gears but they aren't needed but for gas mileage
    But don't try to drag race on the road with em cause you can snap a axle or your driveshaft
    And they will look great black go to vhtpaint.com and check out their wheel paint
  3. agjake11
    agjake11 Suck my tailpipe
    Rosenberg/Baytown TX
    theres a chance youll rub with a tbar crank but if you do a BL will fix it.
    also youll really want gears with 35"s imo or atleast for the time being a tune to change your shift points otherwise your trans will REALLY hate you (also dont let bigun tell you you dont need gears he has a manual haha)
  4. TFIDDLE
    Mine feels fine. I got 35 inch tires with stock.gears and 4.6. I do have a.custom tuned programmer! It really helped.
    Sent From My Samsung Fascinate Using Chuck Norris
  5. .ScRuMpTiOuS.
    Houston, TX
    if i get a leveling kit, will i be ok? or is the body lift still recommended? would i ruin my transmission if i dont get gears?
  6. agjake11
    THIS is why :waytogo:
  7. .ScRuMpTiOuS.
    Houston, TX
    how much do these programmers go for? and what do they do? can i do this myself?
  8. rrogers
    i see no reason for gears. get a tuner,crank the tbars and you should be good to go
  9. agjake11
    leveling kits arent recommended cause theyre a wast of money since you can crank for free and body lifts are only about 175
    and you wont ruin it but it will pop in and out of OD when on the Highway since it thinks you have stock size tires
  10. agjake11
    you can get a regualr edge and run canned tunes or a gryphon and do custom or xcal3 etc
