01f1502wd's all LED swap
Discussion in 'General Discussions' started by 01f1502wd, Jul 24, 2011.
  1. supercrewzn
    I dunno if u have to have it. I used mine.
  2. 01f1502wd
    its just the same as the dimmer switch on the dash factory right? now you have 2?
  3. supercrewzn
    Basically but the cluster may not be a full 12 volts. I would hook that dimmer up and check the voltage coming from the wires. If its 12 volts, the you should be good to go.
  4. DestinationFX4
    DestinationFX4 Admanistrator
    College Station, TX
    I had gauges like that in my mustang, and i didnt use the dimmer switch, I just hid it behind the gauge cluster. I never really dim my gauges anyways
  5. 01f1502wd
    ^ya I dont either. I was thinkin about hookin it up and leaving the switch on full blast and just tucking it up behind the dash.
    thomas, is all I do is just take off the clear cover to my guages and pull the needles off then put that one on top? or do I remove my factory one?
  6. 97madness
    :superhack:
  7. 01f1502wd
    hahaha I dont think i will be using a sawza to do it...ima usin my chain saw. its a lot faster :lol:
  8. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    i have one :)
    but its in my truck :shooter::ROFLJest:
  9. 01f1502wd
    ^sooooooo are you shooting your truck? save that piece...I want it lol
  10. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    Me too
