  1. 01f1502wd
    Just the regular Edge CS, I use the tuner as my speedo, my analog one on the dash I know is off due to gears and tires. Trans should be the same one as you.
    Thats fine dylan....Im just sayin I cant wait to see what 37s will look like.
  2. TxFx04
    :) just waiting for these km2's to wear out but they won't because they're awesome tires
  3. iowaredneck
    They are sweet and do last a long time
    sent from area 51
  4. 2wd supercrew mudder
    2wd supercrew mudder Full Access Member
    texas
    what dose your trans temp run with your built tranny do you use syn fluid?
  5. 01f1502wd
    Its all synthetic, I dont remember what it is though. It runs like normal. I do want to put a super duty cooler on it just to make sure it stays plenty cool.
  6. 2wd supercrew mudder
    texas
    with my e fans my truck runs at 205-210 ect and my trans runs at 200-205 in this Texas heat but i don't want to cook this transmission either
  7. MyFX4Project
    MyFX4Project TRUCKIT
    Kansas
    The texas heat is a big factor when it comes to cooling engine/tranny. I took out my efans because they weren't very trusting. With my mechanical fan my engine runs at 208ish and tranny runs about 165ish. Normally its about 80* over outisde temp for tranny. I've been told 100* over outside temp is normal so basically anywhere from 160-200 is a good range for a tranny. Somebody can chime in if I'm wrong.
  8. 01f1502wd
    Thats one reason why I still have my stock fan, Id rather not chance it with cooking my engine. If there was a kit all plug n play, as ling it was professionally installed, they covered the fans and my engine I would be tempted.. But I dont think anyone does lol
    Trans temps are usually normal, 170 empty and around 200 when towing anything, but I would like that little extra insurance with a bigger cooler
  9. iowaredneck
    You are correct sir. 100* over outside temp for a trans
    sent from area 51
  10. 2wd supercrew mudder
    texas
    The Troyer kit I have is prety easy install the only trouble I had is my short wiring skills but that has improved and there running great in this heat
