04+ F150 rear shock mounts
Discussion in 'General Truck Discussion for all Generations' started by 01f1502wd, Feb 13, 2013.
  1. cowboy
    26 gallons
  2. 01f1502wd
    same as mine.. so I think my fuel pump is located on my frame in the middle of the cab, and the filter is in the tank?
  3. cowboy
    think you got that reversed. My filter is on the frame and the pump in the tank.
  4. 01f1502wd
    ok yeah maybe its that. do you know if 04+ and my 01 fuel pumps are the same? it looks like the general assembly is the same..possibly the mount up..
    The only difference between the 26 and 36g tanks on the 04+ is the 36g is a little longer. All screws, 8fts, and scabs/6.5 could get the 36g as an option.
    You want to replace your tank?
  6. cowboy
    from what I see no they are different. The fuel pump that is.
  7. 01f1502wd
    I want to run outboard shocks. like you have. mine are on the inside of my frame. the ride of my gf's 02 screw stock compared to my buddies '11 scab fx4 has a lot more lean. the fx4 seems to be a lot more stable when cornering with a trailer and without. I will need to go flexing to see if I will have enough room to do it. in the wheel well.
