08 stx 4x4
Discussion in 'General Discussions' started by Ak 08 stx, Nov 1, 2013.
  1. Ak 08 stx
    Ak 08 stx The Only One
    North Pole, ALASKA
    alright guys, so I used half a tank so far, filled up on 1/4 and now on 3/4 and 165 miles. So I figured it out to about 13 mpg so far, and that's both in town and highway driving. That aint to bad for having it only a couple of days. now having my reverse lights shipped and the led hyper flash fix coming in also
    How are you fixing the hyperflash? Buying the relay at Napa is the easiest
    Your mp seems low. Did you reset the tripometer when you filled up? Divide the gallons at your next fill up by miles driven and you'll have your real mpg. the gauges on these truck read funky
    sent from my igloo
  3. Ak 08 stx
    North Pole, ALASKA
    I checked napa and they didn't have a relay for it, I even asked
  4. Ak 08 stx
    North Pole, ALASKA
    well I found a flasher at o'reillys auto store, so what I am going to do tomorrow is install the flasher and bulbs I have on hand, if this flasher don't work I will put the stock bulbs in and put the regular flasher back in and wait till I get home and install the correct flasher. Since I will be gone when my reverse led's come in and the correct flasher
  5. Ak 08 stx
    North Pole, ALASKA
    well guys the flasher didn't work out. it says heavy duty flasher on it but it didn't work, so when I come back from work I will have a set of reverse led bulbs and a flasher ready to install in my truck.
  6. TxFx04
    Is it the tridon EP-27 led flasher relay? That's what I have and it corrected my hyper flash
    Sent from my iPad using Tapatalk - now Free
  7. Ak 08 stx
    North Pole, ALASKA
    no its was a different one from o'reillys its like the redneck version of napa
  8. TxFx04
    Oreillys never has what I need /: I got mine at advanced,
  9. ak_cowboy
    It should say EP-27L The L stands for LED and has the higher resistor in it.
  10. Ak 08 stx
    North Pole, ALASKA
    And i am getting 14 mpg on the truck, had 360 miles in it before I had to fill it up again
