12th gen axles swap
Discussion in 'General Discussions' started by cowboy, Oct 1, 2013.
  1. cowboy
    How do the electric lockers work on the 12th gens? More specifically the switch for the E-locker? I was wondering if the switch is just a switch and not wired into the PCM or the transmission PCM
  2. 97madness
    I think its all part of the PCM's. You would have to look at a 12th gen swap thread to find more. I remember reading a few in the past but dont remember exactly what was changed aside from the switch in the dash and the addition of the locker.
  3. ak_cowboy
    it's all in the pcm. Lots of guys have tried changing it because the anti-spin kicks on above 30mph even with the switch off and a bunch of other e-nonsense.
  4. yz85rider2002
    If you are thinking about doing it in yours, I would just go with an air locker, less crap to deal with
  5. nflfreak43
    nflfreak43 Full Access Member
    Smyrna, TN
    Just get a Detroit tru-trac.. Easier..
    Acts as a standard limited slip most of time but is right enough it's equal to a locker
    Smokin' Tires with my 5.0 on Tapatalk
  6. cowboy
    probably, was just thinking I could find the 12th gen axle's with 4.10 gears and e-locker and do a quick swap without out breaking my diffs open. possibly cheaper too.
  7. yz85rider2002
    If you want to go that right, I would start searching for a wiring diagram
  8. Tradesman
    Tradesman Full Access Member
    Vancouver, BC
    Yup, I'm upgrading my rear differential to a Tru Trac later on when I have more money. My clutches are s**t to hell and it's like I have an open differential now.
    Yeah, I think the ARB lockers are some of the best, but they're quite expensive and generally overkill unless you see some serious dirt.
