1992 F-250 4x4 Build Thread
Discussion in 'General Discussions' started by ksingltn, Jun 16, 2011.
  1. ak_cowboy
    Heck yes!
    sent from my igloo
  2. BlackThundah
    Niceeeeee!
  3. yz85rider2002
    Interested to see this with a write up
  4. ksingltn
    ksingltn Full Access Member
    Anniston, AL
    yep. Will do, just need to round up the little odds and ends like the track bar bracket, track bar and U-Bolts and U-Bolt plates. Gonna sandblast and paint it before I throw it under there too, just to make it look a little better.
  5. ksingltn
    Anniston, AL
    been puzzling on what to do about U-Bolts, since I didn't want used ones and new are expensive. Then I found out that Ford in a rare moment of interchangeability used the same U-Bolts for the D-50 TTB (which I have) and the D-60 Monobeam. So, rockauto to the rescue, $5.48 each.
  6. ksingltn
    Anniston, AL
    got major progress done this evening.
    Finally got around to changing the oil. :jester: All 14 qts of it.
  7. ksingltn
    Anniston, AL
    just ordered the pitman arm, U-Bolts and brake lines I'll need for the D-60 swap. Still need the U-Bolt plate and track bar and mount, and rebuild the brakes on the 10.25 I have to match the ratios.
    Getting closer....
  8. ksingltn
    Anniston, AL
    Part Number Part Type Price EA Core EA Quantity Total
    1992 FORD F-350 7.3L V8 DIESEL
    ACDELCO 52530 Shock Absorber
    Wholesaler Closeout -- 30 Day Warranty $ 22.79 $ 0.00 2 $ 45.58
    BENDIX H7181DP Drum Brake Hardware Kit
    Wholesaler Closeout -- 30 Day Warranty $ 2.70 $ 0.00 2 $ 5.40
    DORMAN C94483 Parking Brake Cable $ 15.06 $ 0.00 1 $ 15.06
    DORMAN C94482 Parking Brake Cable $ 13.81 $ 0.00 1 $ 13.81
    MOTORCRAFT BRS40 Axle Shaft Seal $ 4.17 $ 0.00 2 $ 8.34
    RAYBESTOS 4351166B Track Bar $ 76.79 $ 0.00 1 $ 76.79
    SKF 18888 Differential Pinion Seal
    Wholesaler Closeout -- 30 Day Warranty $ 8.90 $ 0.00 1 $ 8.90
    WAGNER PAB358AR Brake Shoe
    Wholesaler Closeout -- 30 Day Warranty $ 17.84 $ 0.00 1 $ 17.84
    Discount $ -9.59
    Shipping First Class Mail, Ground $ 36.18
    Order Total $ 218.31
    I love me some rockauto. Ordered the last of the parts except the u bolt plate, will order that from Ford tomorrow.
  9. ksingltn
    Anniston, AL
    got these in the other day:
    A really big pitman arm
    (no, the hole isn't egg shaped, my camera did that)
    New U-Bolts
  10. Big'un
    damn man i had some ubolts , u shuda hit me up
