1995 f150 gearing
Discussion in 'Engine & Performance' started by Masonsf150, May 30, 2013.
  1. Masonsf150
    Masonsf150 Full Access Member
    St.louis
    So I have a 302 with a e4od and the rear end is a limited slip with 3.55 gears from the factory. I've topped the truck out at 101 as my bench mark top speed. All I have is a exhaust- cut 2nd cat ran 3" exhaust into flowmaster super 10 and dumped under the bed.
    My question is if I switched to 4.10s what would I see in improvements?
    How much top speed would I lose?
    How much would it affect my gas mileage?- get about 11 now
    At cruising speed- 65-70 I'm at 1800-2100 rpm.
    Would I notice a difference between 3.55 and 4.10?
  2. iowaredneck
    what size tire you running?
  3. Masonsf150
    St.louis
    I'm running a BFG 30x9.5x15
  4. ak_cowboy
    You'll be fine speed wise, acceleration will improve, mpg will be better in town and maybe worse on the highway. Keep it under 70 and you'll be golden
    sent from my igloo
  5. Masonsf150
    St.louis
    Would my top speed decrease?
  6. AK SNO RIDER
    AK SNO RIDER Got Snow?
    Soldotna, Alaska
    Yes, but your also driving a truck, not a sports car.
  7. Masonsf150
    St.louis
    Like when I went to the 1/4 mile I got a 17.1 at 79.89 mph. With the gear change could I possibly even have that speed increase?
  8. ak_cowboy
    For the 1/4mi your speed will probably increase since your acceleration will be greater.
    I've had mine with 4.10s to 118mph and wasn't against the redline, just ran out of power.
    When you got it to 100, was that redline or lack of power?
    Here's a decent calculator.
    http://www.fordfullsize.com/forum/f79/transmission-questions-opinions-10370/index2.html
    4.10s, 65mph, 30" Tire = 2984rpm
    3.55, 65mph, 30" Tire = 2584rpm
    ( With a 1:1 trans, not overdrive)
  9. Masonsf150
    St.louis
    In overdrive I hit 100 an it was lack of power, overdrive off and I was at the tip redline
