1995 loose column
Discussion in 'Interior' started by panhead, Feb 12, 2020.
  1. panhead
    panhead Junior Member
    acme pa.
    how do I fix a loose steering column. problem is at top where it tilts
    More than likely a loose worn bearing at the top.
    Disconnect the negative of the battery for 20 minutes before removing
    any wheel components to let airbag circuit discharge FIRST.
    Second video is a tilt on a F-250, basically the same steering column.
