2 4x4 questions....
Discussion in 'Lifted' started by .ScRuMpTiOuS., Mar 6, 2011.
  1. iowaredneck
    run 4hi for speeds not hight than 50mph.
    4low is for short term use and no faster than 15mph.
  2. yz85rider2002
    ^agreed
  3. Old_Skl_Raptr
    yea sure you CAN do it, im just sayin i wouldnt do it. plus after 45 your gonna have enough momentum to make it through just about anything anyways.
  4. Old_Skl_Raptr
    you could pull a 16ft jon boat out fine with your lawn mower hahahaa
    i was thinkin bigger, like heavy ass bass boats or ski boats, or maybe someone not as good with the gas pedal as you haha
  5. deboer03150
    deboer03150 Banned
    Archer, IA (Northwest, IA)
    what about when the roads are sloppy from snow and other stuff like that
    bottom line in 4 high you can go what ever speed you want to
  6. Old_Skl_Raptr
    if the roads are sloppy from snow and other stuff you shouldnt go over 45 anyways:birgits_tiredcoffee
    but im not tellin you how to drive your truck. im just sayin me inparticular, wont go over 45 in 4x4. i have no reason to.
  7. deboer03150
    deboer03150 Banned
    i know and agree just saying there isn't a limit for 4 high
  8. Old_Skl_Raptr
    agreed. limit in 4 hi is all personal preference
  9. .ScRuMpTiOuS.
    .ScRuMpTiOuS. Full Access Member
    Houston, TX
    1. So if i was in 2wd and got stuck in the sand, would i use 4L to crawl out to a safe spot?
    2. If i was purposely going mudding, would i go ahead and set it in 4H since mud gets a little slippery and i may have to pedal to the metal ?
    3. What gear should i be in with both situations to switch to 4wd?
  10. ak_cowboy
    1) yes. That is the right choice
    2) yes again. Mud is plenty slippery and you want all those tires pulling you through.
    3) you have to be in Neutral to engage 4lo, 4hi can be engaged up to 55mph, but I recommend doing it under 10mph. Or better yet, when stopped.
