2.5 Ton Rockwells to my 2006 F-150?
Discussion in 'Lifted' started by backwoodscountryman, Apr 21, 2011.
  1. backwoodscountryman
    Backwoods
    So what would it take to merry my truck to this 2.5 Ton Rockwell Axles on a straight chassis with leaf springs with all steering components?
    I mean the body itself,the tranny,the motor.Everything?
    And yes i can do all the fab work needed.Cutting/welding,grinding and so on.
    Also how much besides what i would spend on the Rockwells would i expect to shell out for all what i would need?
    Give her a look
    Rockwells
    Or its not even worth it?
  2. mustangwarrior
    NE Ohio
    if you are using that chassis, i dont think it would be all the difficult, would just need to make custom body mounts, motor mounts etc. seem like it would be a fairly easy concept, but i would do it to an older truck rather than yours
  3. cowboy
    I'm with Nick, custom body mounts, engine mounts, and transmission mount and you should be about set. The only think I think would be the steering geometry might change and you could fix that too.
  4. VanoFord
    check the wheelbase length as well. if your those wont match your current wheelbase measurement, you have a bigger headache: either have to chop your truck shorter, or find a way to make it longer.
  5. iowaredneck
    find a different truck to do this too, something older that fits the length
  6. FLfirefighter
    Parrish, Fl
    First i agree with every one else on do it to something older, but i think it would be easier to put the axle under your truck's frame. Then it would be like doing a SAS to your truck, You already have all the motor, tranny, and body mounts there.
  7. jlyoung08
    first off why do u want to do this? lol itd be coool but why
  8. TxFx04
    half tractor half truck..who wouldn't? lol
  9. TFIDDLE
    I like tha idea. Go for it
  10. jlyoung08
    lol i jus want rockwells for my 78
