2" coil spring spacers
Discussion in 'Lifted' started by White_Lightning, Jan 18, 2012.
  1. White_Lightning
    Lovett, Florida
    Are they a true 2" lift or are they callin the spacer 2" and the lifts like 1-1.5"?
    Sent from my piece of shat.
  2. 01f1502wd
    mine came out to be just shy of 2in.
  3. White_Lightning
    Lovett, Florida
    Ten four pretiat it buddy.
  4. 01f1502wd
    no prob. I got em first..then when I went to my 3.5in spindle I got 2in lift coils. cost 100 bux more than the spacers but were an actual 2in..i think really like 2 and 1/8th lol
    I recomend doing the lift coil and only use the spacer if your getting a lift like my fabtech so you can add it for more lift since you cant get a lift coil for that lift..make sense?
  5. TxFx04
    i had a 1.5" daystar spacer and it made my truck sit exactly level
  6. 01f1502wd
    ^Id believe it. I did mine with a 1in block...oops
    when i bumped it up to a bigger lift I took off the 1in and found out it was just aluminum...and it had broke into 2 pieces...be sure your block is steal.
  7. White_Lightning
    Lovett, Florida
    Yes i understand and ill jus go with the spacers bc i already have the 3.5 spindles and i plan on goin to the 7.5 fabtech one day. So they spacers would save money in the long run. And thanks for the input guys much a pretiated.
  8. 01f1502wd
    ya theyre 1/2 easy to put in. cheap way out but it works the same.
    just let me know when you want my lift.....I can do payments :D Im sure we can make a deal.
  9. BlackThundah
    My 1.5'' spacer with spindles and 3'' locks makes me sit completely level. If it were any less or any more i'd be off. I've got the solid rubber one and im shure it gave me exactly 1.5'' of level. I dont know if brands mean anything but mine is a daystar. But you will need a coil compressor.
  10. White_Lightning
    Lovett, Florida
    Yah jarret might be a few months.. Buy im bout done with school and im garenteed a job when im out but. If you still have the lift when i get my first pay check ill deffinatly hit ya up buddy.
    And im not sure if brand names have to do with anything ether...
