2001 Expedition ,no power to coils
Discussion in 'Explorers - Expeditions - Excursions - Broncos -Es' started by 1935 Ford, Jan 5, 2019.
  1. 1935 Ford
    1935 Ford Junior Member
    Strathmore
    I dont have a chart that show wich relay is the ignition relay ,do you happen to know wich one it is? 20190108_115901.jpg
    Fuse box 2002 Expedition.jpg Found a diagram for 2002 but not 2001.
    Says ignition relay is in fuse box inside.
    Top left is location.
  3. Roush PSD Interceptor
    Chart for the Central Junction Box under hood.
  4. Roush PSD Interceptor
    They list a ignition relay for sale to a 2001 Expedition so it has to be either
    in the fuse panel under the dash or under the hood.
  5. Roush PSD Interceptor
    That whole coil powered circuit would need a fuse or relay
    to be safe in case of a grounded out situation, otherwise
    it could backfeed and smoke the entire length of the wire
    to the ignition master switch.
  6. Roush PSD Interceptor
    What kind of access panel do they have for the Expedition to the interior fuse block ?
    Is it on the side like a Ranger or under the knee kick panel like the F Series ?
  7. 1935 Ford
    Strathmore
    Still no good
  8. Roush PSD Interceptor
    Check my last post
  9. Roush PSD Interceptor
    Go for the hot wire jumper if everything fuse and relay
    checked off the list.
  10. Roush PSD Interceptor
    Both VCTs are plugged in ?
    Rereading your earlier posts, what did
    you mean when you said you have power
    at both sides when they are in place ?
