Nitewolf
The Big Bad Wolf
Tie Rod End
Removal & Installation
Inner
To Remove:
1) Safely raise and support the vehicle.
2) Remove tire and wheel assembly.
3) Mark a reference point from the tie rod end to the wheel spindle tie rod adjusting sleeve.
Remove or disconnect the following:
- Inner tie-rod cotter pin and castellated nut
- Tie-rod end using special tool (211-003 or equivalent)
- Tie-rod end by loosening the toe set jam nut, and count and record rotations.
To Install:
1) Install or connect the following:
- Tie-rod end
- Inner tie-rod cotter pin and castellated nut (Torque to 56-75 ft lbs)
- Tire and wheel assembly
- Lower the vehicle.
- Check and adjust wheel alignment.
To Remove:
- Outer tie-rod cotter pin and castellated nut
- Tie-rod end
- Outer tie-rod cotter pin and castellated nut (Torque to 56-75 ft lbs)
