2004 Ford F150 Truck Wheel Bearing & Hub Assembly Front Pair for 4WD Heritage Models
1ATony
Full Access Member
Ma
CHECK HERE FOR GREAT PRICES 2004 Ford F150 Truck Wheel Bearing & Hub Assembly Front Pair for 4WD Heritage Models with 5 Lug Wheels & 4 Wheel ABS
FREE SHIPPING IN THE LOWER 48 STATES!!!
Specifications:
Fits RH and LH FRONT
3 bolt flange
Includes ABS sensor and plug wire
Direct replacement
Replaces dealer part numbers: 1L341104AA, 1L34-1104AA, XL3Z1104AA, XL3Z-1104AA, YL341104AA, YL34-1104AA, YL3Z1104AA, YL3Z-1104AA
Fits 5 Lug Wheel
Studs already installed
Fits only F150 4x4, (w/14mm wheel bolts & 4 wheel ABS) exc. 7700 GVW
Quality
1A Auto exclusive 2 Year Warranty.
If this hub bearing should fail to provide satisfactory performance you may exchange it.
You will not have a problem with our product. If you are comparing us to someone selling a brand name product remember brand names are only as good as the company selling them. Both Bizrate.com and The Better Business Bureau recognize 1A Auto as a trusted online seller. You will be pleased with what you find out about us.
You don't want to be delayed by a defective part. 1A Auto hub bearings are all tested prior to shipping.
Fit guaranteed
This hub bearing will install just as your original does. You can use your existing hardware.
Save time and money with this direct fit hub bearing assembly. No trips to the auto parts store or extra time trying to match up and press bearings.
Hub installation is a degree more difficult than changing a tire on most vehicles.
1. Jack the vehicle up and support with proper jack stands.
2. Have a helper hold the brake pedal while you loosen the Axle Shaft Nut. This usually requires a large socket (30mm or larger) and impact wrench.
3. Remove the brake caliper and brake rotor. Use string or a plastic tie to hang the caliper up and out of the way.
4. Unplug ABS sensor (if applicable)
5. Unbolt the hub flange. The hub may come free from the axle shaft easily, if not, use a gear puller or similar tool that pulls on the hub while pushing on the axle shaft. DO NOT try to drive the axle out with a hammer, this could ruin your axle CV joints.
Reverse order to install.
We were able to do a removal and replace on a GM car in about 45 minutes.
Value
Some shops and dealers charge more for parts and repairs when they think the customer doesn't know what is involved. Now you can get the value you deserve. Knowing what this repair entails can be the difference between the value of doing it yourself, or the pain of a costly part or repair bill.
INTERNATIONAL SHIPPING AVAILABLE
