TSB 05-26-3
FORD: 2004-2006 Ranger
ISSUE
Some 2004-2006 Rangers 3.0L-2V "Vulcan" vehicles may exhibit:
- Malfunction indicator lamp (MIL) on with diagnostic trouble codes (DTCs) P0300-P0306 and P0316
- Rough running at various RPM
- Rough idle
- Misfire
ACTION
This may be due to an engine exhaust valve seat recession causing a loss of compression. Refer to the following Service Procedure to diagnose exhaust valve seat recession.
SERVICE PROCEDURE
1. Perform a power balance rest to clarify if a cylinder is misfiring. Identify and keep record of any cylinder that has a concern.
2. Perform a manual compression test with the spark plugs removed to locate any cylinder that may have low compression. Refer to the appropriate Workshop Manual, Engine System, General Information, 303-00.
3. If no low compression is found per shop manual instructions, proceed with normal misfire diagnostics per the Powertrain Controls/Emissions Diagnosis (PC/ED) Manual for the appropriate model year.
4. If low compression is found and it is a cylinder that had a misfire on power balance, perform a leakdown test to determine the source of leakage that may be causing the low compression. Refer to the appropriate Workshop Manual, Engine System, General Information, 303-00.
5. If low compression is found in a cylinder that did not have a misfire detected then proceed with normal base engine diagnostics per the Workshop Manual, Engine System, General Information, 303-00.6.
If the exhaust valve is identified as the source, replace both cylinder heads with the newly released service cylinder heads. Refer to the appropriate Workshop Manual, Section 301-01A.
PART NUMBER / PART NAME
6U7Z-6049-A / Cylinder Head Assembly
