2005 - 2008 Ford F150 Truck Manual Mirror Extension Pair
1ATony
Full Access Member
Ma
CHECK HERE FOR GREAT PRICES 2005 - 2008 Ford F150 Truck Manual Mirror Extension Pair
FREE SHIPPING IN THE LOWER 48 STATES!!!
This mirror extension Pair is just what you need to add the ability of turning your normal, non towing mirrors, into the camper style towing mirrors!
This mirror pair features the following specifications:
Comes as a PAIR
Can be easily removed when not needed
Designed to give the factory look when installed
Extends towing vision for added safety
Uses a patented "Snap" system to install them securely to your existing mirrors
Mirrors are infinitely adjustable and will not vibrate out of position
Will not interfere with adjustments of the factory mirror glass
Factory mirrors can be folded without having to remove the extension mirrors
Installation instructions included
Uses foam strips to protect the back of factory mirror housings
Fits new body style F150 Pickups with or without heat function & with or without puddle lights
Factory mirrors shown as examples are not included
Will not fit manual, dual arm, or telescoping mirrors
Makes a great addition to any New Body Style F150 pickup that currently has standard mirrors that will be towing trailers!
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
INTERNATIONAL SHIPPING AVAILABLE!!!!
