35s and Gears Question
Discussion in 'Wheels & Tires' started by 2001_4.2, Aug 15, 2011.
  1. agjake11
    agjake11 Suck my tailpipe
    Rosenberg/Baytown TX
    what trans do you have. i wouldnt go with 4.88"s
    4.56 will do you good either way
  2. 2001_4.2
    2001_4.2 Full Access Member
    Manual, M5OD.
  3. agjake11
    then 4.56 is the max you want to go with. 4.56 and the OD gear in the manual trans is a tall gear and with 35"s is almost too much gear
  4. 2001_4.2
    Will 4.56s and 35s give me a little bit more "pep" than stock gears and stock size tires?
  5. agjake11
    yes. my truck ran great on 4.56 and 35"s and would go easily from 70 to 85 in OD no downshift
  6. 2001_4.2
    hmmm i think I'm leaning towards 4.56s now, especially coming from a guy that has had the 4.2. Thanks man.
    Where did you buy your gears? I'm looking to buy from diffsonly.com
  7. Swagger68
    Swagger68 Full Access Member
    Superior, WI
    not to jack the thread or anything.....I'm thinking about doing the same....I have an '07 4.6l STX 4x4 and a 3" level. Do I need new gears too?!?
  8. TFIDDLE
    ^im about to and ive got a 4.6!
  9. cowboy
    depends on what your doing? If your not going to jump sizes in tires then there is no need for it.
  10. VanoFord
    its not the size of your engine that is the determining factor, but your original R&P. I assume w/ your 4.2 that you have atleast the 3.55?
    Here is the formula to figure out the proper gear to get you back w/in factory powertrain specs.
    (New Tire Size DIVIDED BY oem Tire) TIMES Oem R&P = New R&P.
    Example of my truck:
    35/30= 1.1666 * 3.73= 4.35
    Because of that, I went w/ the 4.30, which you can get as a ford part since they make that R&P for the mustang's 8.8.
