4R70W w/ OD
Discussion in 'Engine & Performance' started by jake1, Sep 24, 2013.
  1. jake1
    jake1 Junior Member
    Help everyone, I seem to be having an issue with my transmission. From a stop everything goes fine, but once I hit about 70 mph in od I cannot remain there on the smallest incline. It will shift between 3rd and od until I reach level road again. I like to run shoot 68-70 that puts me right around 2k rpm. This is running empty no load what so ever. Any input ifs welcome. Thank you
    Sent from my DROID RAZR using Tapatalk 2
  2. 07Fx2
    07Fx2 Full Access Member
    Oklahoma
    Sounds like it's not a tranny issue but a power problem. How many miles is on your truck and what model/motor?
  3. iowaredneck
    We need more info....doesnt sound that uncommon
    sent from area 51
  4. 07Fx2
    Oklahoma
    That's what I'm thinking. If it's a 4.6 it's pretty common haha :3
  5. jake1
    jake1 Junior Member
    Sorry, 95 f150 5.0 with 78k mi.2 wd sc lb.
  6. ak_cowboy
    When was the last time the fluid was changed?
  7. Roush PSD Interceptor
    ^^^ This
  8. jake1
    jake1 Junior Member
    Trans was serviced last year with fresh filter and fluid. Less than 5k mi
  9. Roush PSD Interceptor
    Reading about other people with a similar problems:
    Wires at transmission were damaged.
    VSS (Vehicle Speed Sensor) flaky defective (at rear diff)
    may not be sending a steady speed signal in turn telling
    the transmission it needs to shift from OD to third and back and forth.
  10. UtahFord
    What he says ^^ replace your speed sensor see if that helps its about $20 for a new one
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
