My 4wd problems have been getting worse. I have the electronic shift on the fly. Often times, if Im stopped, and put it in 4, when I start to go, things are okay for a few feet, then it will clunk/jolt and put itself in 2. Then it'll randomly go back into 4 with a clunk and a jolt. For example, the other day I was pulling out of work in 4. About halfway out it randomly put itself in 2 and almost spun me around. But then it grabbed 4 again. I'm thinking something in the T-case, maybe whatever switches it back and forth? Any ideas?
My first thought was switch too. But when the switch is turned there's a noticeable click from the switch. And since this click doesn't happen, it leads me to believe its down in the t case. I'll check/clean connections sometime in the next few days, that would make sense. In the meantime, more suggestions welcome Sent from my Xoom using Tapatalk
Probably same reason I do. Driving in town sucks right now, all the stop lights and stops signs are icy as sheet. you have to have 4wd just to get going 1/2 the time
thanks. And yes, the intersections and side roads are really slick, and even my winter tires are just about useless. Sent from my Xoom using Tapatalk
