5'' rcx lift w/35's made homemade hitch to pull gooseneck 4.6 5speed
Discussion in 'Lifted' started by yamahasled, Apr 13, 2011.
  1. VanoFord
    :waytogo: never owned a 97-03 so i wasnt sure, but knew 30 didnt sound right. thanks!
  2. agjake11
    agjake11 Suck my tailpipe
    Rosenberg/Baytown TX
    np. the rear 8.8's are 31 on the 04-08's also. the 28 spline rear 8.8's are mustang and explorer axles
  3. Predatory Instincts
    Burger King's bathroom
    3.73's were optional on the XLT but a 255/70 is a 31" tire and the standard size for the 4x4 XLT.
  4. yamahasled
    yamahasled Member
    Rosendale WI
    this is what I made up. . I still have to drill holes in the 4''x3/8 piece of flat so I can bolt it to the hitch witch bolts to the frame
  5. ranger
    ranger Full Access Member
    Fond du Lac
    Little do you kno we picked up a yota and droped it off right before
  6. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    U still gotta tune the 4.6 after u build it
  7. ADTR288
    ADTR288 Full Access Member
    Phoenix, Az
    pretty sure you have this backwards... supposed to be 30/35*3.55=3.04
    caus i have 30/37*3.55=2.87 and thats why i need to re gear to 4.56's cause
    30/37*4.56=3.69 bringing me closer back to stock gear restoring gas mileage and torque putting less stress on the drivetrain
  8. VanoFord
    No, its correct. 37/30*3.55= 4.378 which is how you get to a 3.55. if you went 37/30*3.73 = 4.60 which a 4.56 would put you back to stock w/ a 3.73 gearing (which ford did do and would be acceptable and tollerable by your tranny). If you think I am wrong, google it.
    Your way of thinking is correct too, since you did it this method:
    (Oem Tire Size DIVIDED BY New Tire Size) TIMES New R&P = Oem R&P
    all you did was solve for Y, when I solved for X. same result. try not to insult people before you do your research. :flipthebird:
  9. VanoFord
    a tune ain't nothing. doesnt require an ecu, or anything fancy like a 5.4 will. just an afternoon at the dyno shop.
  10. cowboy
    :popcorn: nice hitch btw.
