82 f150 one owner changed thermostat & heat sensor-
Discussion in 'Engine & Performance' started by kelly carter, Mar 21, 2025.
  1. kelly carter
    kelly carter Junior Member
    tulsa
    changed thermostat w/192 degree thermostat. Engine has always run at first mark on temp gage of cold/normal mark. Now close to normal/hot. Have burped engine, have flushed engine. After flush normal.. Started with thermostat, heat sensor change. Also, burped radiator. It is a 5.0 liter V-8.
