justruckin
Full Access Member
ok .... just going to say it ... im a AMC/mopar guy.. that being said i have built some 289's that would twist 8k and still be making power up there. what i working on now is my 76 shorty. it has a 83 351W HO in it and looking to do something to liven it up a bit.
not going to do anything worth swapping heads over but do want to do something.
from what i know about sbf heads the spent gas ports kinda suck and is the weak spot.
what i have now parts wise are a performer rpm air gap dual plan with a 1 inch open Willson spacer. 625 afb. 600 seems to be the good cfm for a stock mill but with the intake and long tubes i should be ok.
4.10 gears with a mini spool in the 9in rear and 28 in tall tires. (and ya it wheel hops bad)
now i have a set of full roller 1.6 rockers but not sold on useing them. so
any input on a cam is what im after. a nice sounding one would be a nice thing but im more into something that would work more than sound good. if i was just after a lopeing mill id put a 292 in it.
i have figured that anything over a 500 lift would be a waist with the stock head but maby more deration would be better..
should i go to the D7's over the early (non smog chamber) D8's i have now?
so what are yall running in your street mill's without a bunch of head work???
thanks
thanks
