92 F350 7.3 engine compartment wiring diagram
rhensonsr
Junior Member
Nashville
I have a 1992 F350 with the 7.3l diesel. I smelled a electrical burn then the engine died. Could not find a burnt wire and noticed the fuel pump was not pulsing, so I ran a jumper to the positive line on the fuel pump and it started right up. Drove it home and the key would not kill the engine until I disconnected the jumper. Does anyone have a wiring diagram so I can find the short? TIA!
Sounds like the jumper ended up feeding whatever the key normally cuts off, so it kept running. With that burnt smell I'd look at the fusible links and the wiring near the starter relay first. The 92 Ford EVTM wiring manual is the diagram you want, they turn up on eBay pretty cheap. Let us know what you find.
