My 94 f150 xl 6 cyl. I've had fuel pump issues last and had to replace both fuel pumps and filter and selector switch....now the issues are back front nobody how much gas is in it feels like we are running out of gas until u toggle switch back and forth then it corrects for a couple miles...the rear does the same thing except the engine sounds like it is missing,stuttering. Not sure what it could be? Thanks in advance Sent from my LS670 using Tapatalk
did you replace the fuel pump on the frame rail? i know you said you replaced both pumps but i assume you mean the ones in the tanks. there is another one on the frame rail that everyone forgets about.
I post a thread and then see this. This is pretty close, close enough it worth a look. New to the F-150 (1995) 5.8. Where on the truck is this located (is there a seperate one for each tank. I ask because mine only seems to have a problem in the AFT position Thanks Vj
