Nitewolf
The Big Bad Wolf
Shock Absorber
Removal & Installation
To Remove:
1. Safely raise and support the vehicle.
2. Support rear axle housing assembly with a jack.
3. Remove or disconnect the following:
4. Lower shock absorber bolt.
5. Upper shock absorber nut.
6. Shock absorber.
To Install:
1. Install or connect the following:
3. Lower the vehicle.
To Remove:
***WARNING***
Only lower the rear axle enough to access the rear spring.
6. Shock absorber.
To Install:
- Shock absorber
- Upper shock absorber nut
A) Torque to: 22-29 ft. lbs. (30-40 Nm) - Lower shock absorber bolt
A) Torque to: 56-75 ft. lbs. (77-103 Nm)
