Nitewolf
The Big Bad Wolf
5.4L Supercharger Installation Procedure
To Install:
1.Install the CAC.
2.Install a new gasket.
3.Install the new bolts.
4.Install the upper intake manifold.
5.Install the upper intake manifold and the four rear bolts loosely.
6.Install the CAC hoses.
7.Install a new gasket.
8.Install the vacuum hose.
Supercharger fastener tightening sequence
9.Install a new gasket and install the supercharger and plenum assembly, bolts, and the stud bolts. Tighten the retainers in two steps, in the sequence shown.
11.Install the EGR vacuum regulator bracket and install the nuts.
12.Position the bracket and install the nuts.
13.Position the CAC water supply and return tubes and install the nuts.
14.Install the CAC hoses and the clamps.
15.Fill the CAC cooling system.
16.Install the accessory drive belt.
17.Install a new gasket and install the throttle body spacer.
18.Tighten the bolts in two steps.
20.Connect the brake booster vacuum line.
21.Connect the vacuum line.
22.Install the bracket bolt.
23.Connect the exhaust gas recirculation (EGR) valve.
24.Connect the vacuum line.
25.Connect the EGR vacuum tube fitting.
26.Install the accelerator cable bracket and install the three bolts.
27.Connect the throttle control linkages.
28.Connect the speed control actuator cable.
29.Connect the accelerator cable.
30.Install the throttle return spring to the throttle lever.
31.Connect the vacuum lines and the vent hose.
32.Connect the idle air control electrical connector.
33.Connect the throttle position (TP) sensor electrical connector.
34.Install the air cleaner outlet tube.
35.Connect the battery ground cable
To Install:
1.Install the CAC.
- Step 1: Tighten to 2 Nm (18 inch lbs.).
- Step 2: Tighten 45 Nm (33 ft. lbs.).
***WARNING***
The throttle body spacer sealing surfaces are soft metals. Carefully clean both sealing surfaces.
***NOTE***
Inspect the throttle body spacer gasket and install a new gasket if necessary.
- Step 1: Tighten to 10 Nm (89 inch lbs.).
- Step 2: Tighten an additional 90 degrees.
***NOTE***
Pay attention to the throttle return spring orientation. It must be reinstalled in the correct orientation.
