AAL or just add a lift block?
Discussion in 'Lifted' started by n-3-s-l-0, Mar 23, 2014.
  1. n-3-s-l-0
    n-3-s-l-0 Full Access Member
    Rogers, MN
    Since I leveled my truck last summer ive been wanting to lift the rear end a little bit so that when i tow my four wheelers and boat around it wont be sagging in the rear. So ive been looking at either replacing the stock lift block with a bigger one or buying and add a leaf kit.
    What do you guys think? Is there a brand that is better than the rest? Is installing an add a leaf an easy task or is it pretty difficult, Ive never tore apart a rear suspension before.
  2. 01f1502wd
    add a leaf IMO. it will add more payload (by maybe 1-200 lbs) but only lift it maybe 1/2-3/4". a block is usually cheaper, measure out how much lift you need, then add the height of the stock block and thats the size you need.
    brands: I like rough country. need something made out of solid steel. I have had alunimum and its broken before.
  3. TxFx04
    Add a leaf for lift and functionality
  4. ak_cowboy
    Aal! It's only like $120 and helps with towing and payloads
    sent from my igloo
  5. DestinationFX4
    DestinationFX4 Admanistrator
    College Station, TX
    If it's just for sagging I would go with airbags
  6. 4ctNduction
    T-E-X-A-S
    add a leaf is what I would do for customers, but another cheap way is just do a bigger block. fab tec #bk15 and u bolts. we sell stuff for the rear for about a hundred bucks
  7. ak_cowboy
    A block isn't that much cheaper than an AAL, and you get a better payload with AAL, and less axle wrap
