Ak_cowboy's Build Thread
Discussion in 'Under Construction' started by ak_cowboy, Nov 28, 2010.
  1. ak_cowboy
    so? you still need a key in all the high end cars that have this too. Its stops ppl from moving my truck around at work. I also installed a valet switch so that I can take to to the dealer and not have them worry about the key working or not
  2. Ak 08 stx
    Ak 08 stx The Only One
    North Pole, ALASKA
    so do you just put your key in and push to start, or do you still have to turn it
  3. ak_cowboy
    You put the key in and turn it to "ON" then hit the button to start. You have to have the key to unlock the steering wheel at the very least
  4. TxFx04
    nope, in my grandmas hyundai sonata all you do is get in, hold the brake down and push the button to start. then just put it in park and push it again to turn it off
  5. cowboy
    pretty cool
  6. ak_cowboy
    well la-de-freakin-da :jester:
    No way to do that mod to a F150 yet. :Wedgie:
  7. cowboy
    makes it real easy to steal too.
  8. jlyoung08
    my moms lexus you have no key abut you have to have the key fob within a certain number of feet or it wont start and if you drive off with out it the car dies
  9. Darth Bama
    Nissan/Infinities have been on the push button start for years. Our Altima doesn't have a key, just a keyfob. That keyfob allows you to lock/unlock the doors, open the trunk and start the car. Once in the car you just press the brake and push the button. You can also play the stereo without the keyfob being in the car if you press the start button one time.
  10. jlyoung08
    same here^^^
