Anyone with Halo Headlights?
Discussion in 'General Truck Discussion for all Generations' started by Dawgfan54, Apr 16, 2012.
  1. cowboy
    you will need a relay. The general Bosch 30A relay is fine
    Amazon.com: Scosche RLYBSCH Bosch Relay 30 Amp: Car Electronics
    here is the digram look at circuit 2
    Relay 101
    use your orginal line that powered the grill light place that on pin 85, pin 86 goes to ground.
    Take a wire from your battery place a 20A fuse on the line and put it on pin 30.
    Then take pin 87 and run that to your lights.
    Here is why we use a relay
    Circuit 2 - A proper circuit with a relay and fuse.
    - The switch is only switching the relay. It draws a very small current which is good for the switch and whatever power source has been used.
    - There will be little or no voltage loss using a relay. A light burns brighter and lasts longer when supplied with proper voltage.
    - All the high current is kept between the battery and lights and is properly protected by a fuse.
  2. Dawgfan54
    Dawgfan54 Full Access Member
    Will they still turn on with my parking lights though?
  3. cowboy
    yeah
  4. VanoFord
    Learn that boy NICK!
    Relays FTMFW!!
  6. Dawgfan54
    Okay so I bought the relay, came home and wired everything up correctly and my lights still look the same. Im rather disappointed :/
  7. UtahFord
    you look at them at night????
  8. Dawgfan54
    Yup just got done around 8:25 tonight and they look the same. I'm pissed I paid the extra $30 for the "brighter CCFL HALOS", and I'm curious, and considering wether or not to call the company and make sure they sent me the right ones...
  9. UtahFord
    hmmm intersting ya call them up man
  10. cowboy
    :hmm:
