i think my passanger side ball joint is going out. when i am driving down the road i can hear it squeak and i hear it squeak when i turn the wheel at low speeds. any thoughts?
Jack front end up push on wheel at top then bottom watch for movement in then its either ball joints or wheel bearings Sent from my SPH-M920 using Tapatalk
if you really wana check it then take the steering knuckle off and grab the threads of the balljoints and if you can move them around in the joint then its time to replace
omg...dood....just jack the damn thing up and grab the tire on the sides and then the top and then shake it...if you have play in it do it again and lean in and see where the play is and you'll find the problem balljoint whether it be top or bottom
