Bed Liner Rockers
Discussion in 'Exterior' started by n-3-s-l-0, Sep 28, 2014.
  1. n-3-s-l-0
    n-3-s-l-0 Full Access Member
    Rogers, MN
    Alright I know that plenty of people do this and honestly I dont really like it but the paint on the bottom of my rockers is peeling badly and I want to do something about it. Money is a bit tight so I cant really afford to have it Line-X'd so I need to do it myself. Would it be easier to use a roll-on application or a spray-on application? Or does anyone else have other ideas rather than bed liner?
  2. TxFx04
    i did rustoleum rattle can bed liner on my old truck, didn't even prep it. Did about 4 solid coats and it held up pretty well with pressure washing and such.
  3. n-3-s-l-0
    Rogers, MN
    Ill have to look into that.
  4. ak_cowboy
    DId the same thing. Rockers held up great, bumpers need retouched every now and then.
  5. cowboy
    same rustolum rattle cans. Works great on the cheap.
  6. Pity7700
    i think I rolled mine one when I replaced my driver side rocker. I want to say its rustoleum just like everyone else. holding up pretty good. I did put a layer or two of por-15 over top of it too.
  7. forduke
    forduke Member
    GA
    I used duplicolor and it works great. But whatever you choose, just prep the surface really well so that the bedliner will stick hard and last longer.
  8. StormF250
    StormF250 Member
    West Milton, Ohio
    I had a truck that I just sold that had Rhino Lining on the rockers and door bottoms, it was ok, but was starting to peel on the doors.
    It was already done when I bought the truck, otherwise I would have spent a little more for Line-x.
  9. FofTworide
    FofTworide Full Access Member
    GA
    I know a guy here use duplicolor and it lasts.
