carid
Preferred Vendor
- Joined
- Jul 22, 2014
- Posts
- 650
- Reaction score
- 329
- Points
- 63
- Location
- Cranbury, NJ
- Website
- www.facebook.com
We're excited to announce that CARiD now offers Belltech's 2" Lowering Spindles for 2021-2024 Ford F-150 2WD models. These spindles lower your truck's front end by 2 inches, giving it a more aggressive stance without compromising ride quality. By relocating the wheel mounting point higher on the spindle, they maintain proper suspension geometry, ensuring stable handling and a smooth ride.
americantrucks.com
Crafted from high-strength ductile iron castings and powder-coated for durability, these spindles are built to last. They utilize factory ball joints and tie rod ends, making installation straightforward without the need for additional modifications. However, it's important to note that these spindles require the use of 20-inch wheels or larger to ensure proper clearance and fitment.
belltech.com
Lowering your F-150's center of gravity not only enhances its appearance but also improves handling by reducing body roll. Belltech's design ensures that the factory ride quality is retained, so you can enjoy a sportier look and feel without sacrificing comfort. If you're looking to give your F-150 a stylish drop with reliable performance, these Belltech 2" Lowering Spindles are a solid choice.
Belltech® 2353 - 2" Lowering Spindles
https://www.carid.com/belltech/2-lowering-spindles-mpn-2353.html
Fits: 2021-2024 Ford F-150
Features:
- Relocates the wheel mounting point higher, creating a corresponding drop in ride height
- Gives your vehicle an aggressive look while maintaining correct suspension dynamics for stable ride and handling
- Lowered ride height reduces body roll due to a lower center of gravity
- Reduces understeer
- Crafted from reinforced steel and coated with durable powder coat finish to resist corrosion, chips, and scratches
- Limited lifetime warranty
- Manufactured in the United States
You can learn more about the Belltech brand here:
https://www.carid.com/belltech/info/about.html
