Hey Six, What were the lengths for your cables? I'm going to judo-copy your efforts... No reason to try and figure it out, when someone has already done the heavy lifting!
i didnt even measure them. i put the wire where i wanted it and marked the length and cut them. but the first 3 are the same length. About 11" each. If I was to do it again I would make two of them 11". One 17" and the rest for the last one. I was going to route mine so they were less visible but I misjudged the lengths
Thank you sir! nicely done. ill make sure to cut my battery to frame shorter i gotta do this soon...especially since i just put a new alternator in
yeah i got lucky on the battery to frame. it was almost too short! i had to route it just right for it to work
yes, 7 ft is the perfect amount. i had 1ft of cable left that i should have used but thats only for the grounds. you would still need wire for the positive cables. but maybe only 3ft of that. im going to order that but in red.
yea im doing the same. Tyler gave me a website to get some good wire i think its like $2.50/foot for the black and $3.01 for the red. i just have to order it and find time to install it. im also thinking about getting another fan controller so i can hook the other fan up to the A/C.
josh, im looking at my grounds right now. it looks like the ground wire from the battery to the frame runs all the way to the fricken starter. the only ground wire i have on the passenger side frame is a wire from the stater mount. am i missing something? did you just change the ground location?
