I have a 2008 Ford Expedition. I just replaced the front blower motor and the resistor. Now it is making a wheezing noise. You can hear the fan change speeds, but there is no change in the output of the air. It's almost like one of the lines for intake or output is clogged. The air coming out is on very low speed. I have looked up where the blower mower is installed for debris and also where the resistor goes. Where else can I look or what else could be the problem. Thanks - a frustrated single mom
Does your 2008 Expy have the Electronic Automatic Temperature Control? TSB 08-9-1 05/12/08 EATC BLOWER INTERMITTENTLY INOPERATIVE -STUCK ON HIGH/OFF FORD:2007-2008 Expedition LINCOLN:2007-2008 Navigator ISSUE Some 2007-2008 Expedition and Navigator vehicles equipped with ElectronicAutomatic Temperature Control (EATC) may exhibit a condition where theblower motor is inoperative no matter what speed or temp setting or the blower motor is stuck on high speed or off. Cycling the ignition may resume operation. The concern may also occur when using the electrical power point. ACTION Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE 1. Open the glove box and remove Connector C297 from the Heater Blower Controller Module (HBCM). 2. Remove the right front door scuff plate. 3. Remove the right side kick panel to gain access to Ground G200. 4. Cut black/white wire about 8" (20.3 cm) from C297. Strip the end 1/4"(6.3 mm). 5. Obtain pigtail kit and using the approved splicing methods found in the Wiring Diagram (WD), Cell 5, crimp the butt connector and seal (with shrink tubing) the splice between the 13" (33 cm) pigtail and the black/white wire from C297. 6. Disconnect the existing 14401 single ground eyelet from G200 and cut existing eyelet from the ground wire. 7. Strip 1/4" (6.3 mm) insulation from the 14401 ground wire. 8. Using the approved splicing methods found in the WD, Cell 5, crimp the butt connector and seal (with shrink tubing) the splice between the 3"(7.6 cm) pigtail and the 14401 wire. 9. Attach the new interlocked ground eyelet to G200. Torque to 11 +/- 1.6lb-ft (15 +/- 2.3 N.m ) 10. Install the right side kick panel and scuff plate. 11. Replace the HBCM. 12. Attach C297 to the HBCM. 13. Close the glove box door.
