Blowing Fuse
Discussion in 'General Discussions' started by ak_cowboy, Apr 7, 2011.
  1. ak_cowboy
    Yesterday I drove to work with no problems. When I left to go home my interior lights, radio, fog lights, windows, and gauges didn't work. So I drove home and found fuse 21 had blown. Replaced it 'pop' blew again... manually shut off interior lights and it doesn't blow. Everything works except my fog lights...
    I also have dtc P0462, which says something about my fuel sensor module not getting enough voltage.
    What the heck is going on?
    All the wiring I did was Sunday and it all worked till Wednesday night...
  2. VanoFord
    i would bump the fuse up by atleast one fuse. your HID require a 20 from the standard 15, or it can melt in the fuse box. also, anytime you start tapping to run power to other areas, you just increased the amp you are drawing, thus needing to upgrade the fuse. this could also be the reason for your code you are throwing... voltage normally went there, now some of it is being diverted for your add-ons thus not supplying what it should have been? just a thought.
  3. Predatory Instincts
    Burger King's bathroom
    You could have also rubbed through a wire jacket in 3 days of driving that just shorted out.
  4. ak_cowboy
    I'll replace the 15 with a 20 and see if that works. I really don't want to take my interior apart again...
    *edit* blew the 20.... looks like I'm tracing wires tonight
  5. VanoFord
    If you just blew the 20, then you have a frayed wire someplace that is tripping it.
  6. cowboy
    ^x2
  7. ak_cowboy
    That's what I was afraid of. I'll let you know what I find tonight.
  8. rrogers
    Good luck man
  9. iowaredneck
    yeah good luck, sounds like you are shorting a wire somewhere
  10. yz85rider2002
    yeah I agree with everybody else, sounds like you got a short somewhere
