Blowing Fuse
Discussion in 'General Discussions' started by ak_cowboy, Apr 7, 2011.
  1. ak_cowboy
    Haha ok ok.... I know I got a short tied in with my map lights, I'm getting new wire and redoing it tonight.
    Got her sorted out. Had the wire rub against one of the A-pillar bolts. Snipped that out, respliced, and wrapped up with some wire loom. Good.To.Go!
  3. VanoFord
    :waytogo:
  4. Pity7700
    Do not up the size of the fuse. you could end up cuasing more damage that way, you should always replace a fuse with the properly rated fuse. glad you found the problem though, short to ground can cause lots of problems.
  5. supercrewzn
    I always suggest the add a fuse or a seperate fuse box for all the accessories.
  6. ak_cowboy
    I added inline fuses to my lights and mirrors, but since puddle lamps came factory tied into maps, I figure I'm ok.
    Vano - how do you use a voltmeter to determine the electrical draw of something?
  7. cowboy
    YouTube - HD Multimeter tutorial
    current is amperage
