Brake pedal won't return
Discussion in 'Tech Info' started by mazak5962, Mar 12, 2016.
  1. mazak5962
    mazak5962 Junior Member
    Winchester, Tennessee
    Hey fellas, I'm new here. I have a 1999 f150. When I apply the brakes, the brakes work fine, but when I lift my foot off the brake pedal, the brakes stay engaged and the pedal does not return. I have to put my foot under the pedal and pull up, then the brakes release. Any ideas???
    Mitch
    Welcome Mitch.
    Look at the pedal assembly under the dash to see if
    The pedal return spring is broken.
    If it isn't broken, the master cylinder shaft is sticking in it's bore.
    @mazak5962
    Pity7700 likes this.
  3. mazak5962
    Ok, thx, I'll check spring out. If it's the master cylinder shaft sticking, what is the fix? Replace master cylinder?
    Mitch
  4. Roush PSD Interceptor
    How much contamination is in the master cylinder resevoir?
    Maybe you can flush it out by gravity bleeding it and working the piston with fresh clean fluid in it.
  5. Roush PSD Interceptor
    How is it going Mitch?
    Any luck flushing the old master cylinder?
    @mazak5962
