Build Thread
Discussion in 'General Discussions' started by n-3-s-l-0, Jun 6, 2013.
  1. n-3-s-l-0
    n-3-s-l-0 Full Access Member
    Rogers, MN
    Alright so I have been wanting to play around with my Edge for a while now, but I'm worried that I will change something and screw it up. So can anyone help me out here? I wanna run it on Level 2 and I want the shifts to be crisp, I want it to GO when I hit the throttle, I want it to run smooth and feel like it has extra power. Can anyone give me an idea as to what I should change?
    Im running 285 70 17 tires, 3.73 gears, and a K&N filter with stock intake.
    Level 2 is fine, make sure that your tire size is updated. Change Shift firmness to +7 for 1-2 and 2-3 shift. Make the shift points at 5000rpm, and max rpm at 5400. Let me know how that feels
  3. n-3-s-l-0
    Rogers, MN
    Having the shift points at 5000 seems pretty high. I dont know if I wanna run it up that high all the time.
  4. ak_cowboy
    That's only for the full throttle shifts. Regular shifts will still be at the regular mph
    sent from my igloo
  5. n-3-s-l-0
    Rogers, MN
    Alright, these are American Eagle Alloy series 015 in the Ice Clear Finish. Got 287/70-17 Kenda Klever A/T tires. So far they are pretty quiet and they seem decent. I guess ill know in about 10,000 miles if theyre really worth the money.
  6. iowaredneck
    Truck looks good. Rims go well with the truck.
  7. n-3-s-l-0
    Rogers, MN
    Thanks Man. I think it will look better once I get the chrome rocker trim peeled off.
    Now I gotta paint my calipers because they are lookin crispy.
  8. n-3-s-l-0
    Rogers, MN
    So I was experiencing what I believe to be a misfire at low rpm when i was in OD. I just got a new set of Ignition coils today, I have never replaced coils before, is there anything I need to make sure that I do?
  9. Roush PSD Interceptor
    Dielectric grease on the spark
    plug end wound wire and
    electrical harness plug in contact points.
  10. n-3-s-l-0
    Rogers, MN
    So just put a dab of dielectric grease on the little wire in the coil itself and a little on electrical plug-in connection?
    Do i need to disconnect the battery when changing coils?
