Custom Headlights
Discussion in 'Exterior' started by ak_cowboy, Aug 28, 2013.
  1. ak_cowboy
    I'm going to be cutting up my heads for my Mini H1 retro soon(ish) and plan on doing a couple other things while they're opened up. The entire headlight is going to be blacked out, including the shroud and stock reflector bowls. I want to take some single row led strips and fill in the 3 lines above the turn signal, and maybe add an angel eye circle to the turn signal pod also.
    Does anyone know if they make amber/white led strips? or angel eyes? It'd be pimp to have them all switchbacks, but if not I'll just get all ambers.
  2. TxFx04
  3. cowboy
    not sure about the switch backs... Somebody could build you some. It takes a little bit of wiring and a small IC.
  4. Stangshcky12
    PA
  6. 01f1502wd
  7. Stangshcky12
    PA
    If you get the led strips I would tint them if O was using them in a headlight
    They aren't all the noticeable but it would bother me in a headlight, I use the same style for bed lights and the are more then bright enough to tint
  8. 01f1502wd
  9. AKBray907
    Realistically how bright would something like that be? If you can only see them when it's dark that kinda defeats the purpose IMO
  10. TxFx04
    I think like my switchbacks they'd be for looks, he wants teh cool looking headlights yo. You sure you want to go with a mini H1? much easier to retrofit but you sacrifice actual output.
