so I'll be using an sdr system for the fm radio in the truck, only issue is it uses the usb input for the tablet and so I wouldnt be able to charge it, so going to splice into it so that the 5v 1.5a switched power will charge the tablet and power the sdr receiver at the same time ** I wrote the wrong thing in the drawings an just now realized it, the cable going into the the tab is an otg cable for the sdr dongle with the power spliced in**
Wow dude, this is crazy, I don't know halfs o the werdz you're talkin. Sent from My Porcelain Throne using Tapatalk
So tablet is here. To clean up the look I made a steel plate that'll expose just the screen but hide the Samsung script and such. I will fiberglass this plate into the radio bezel an it'll also allow me a perfectly flush surface for the tab to mount against. On the rear I will make a fiberglass mold of the back of the tablet that'll Bolt to the protruding edges of the steel plate allowing me to fully secure the tablet in. Pics with the tape are just test fitting an then the last one the tablet is just being held in there by pressure no mount yet. The steel plate will be molded an fiberglassed in so that there won't be that flat edge there
So messing with the coding so that the tablet wakes up when it senses power from the power cable and goes to sleep when no power ie truck on or off. Well thought it'd be cool to add a voice to that when I start my truck, idk what I've done but this is so freaking creepy hahaha Creepy greeting android - YouTube
