Welcome aboard the forum
@OLD N IN THE WAY
So many fuel mpg improvements can be made on the Powerstroke over a gas burner.
I was getting 17+mpg pulling a 7K Aruba with slide out from Chattanooga to Daytona and back.
Unloaded I get 22+mpg on paper and not the PCM read out in over head console.
Knowing the hyper mile tricks and running the chip on tow and eco mode when appropriate.
Check out
https://powerstrokehelp.com/
There are over 75 topic videos here.
Bill Hewitt is in Atlanta, GA close to me and is the only person I would trust on a total rebuild
on my 7.3L
Many would argue the transmission is the weak link on those trucks.
I have over 172K on mine and faithful change fluid and filter, installed the
Bully Dog Shift Kit, additional fluid cooler with fan and have the Raybestos magnetic
inline filter.
Something else that surprises new to diesel engine owners is the oil capacity.
13+ quarts on an oil change plus the $10 oil filter. I always suction drain the HPOP
which hardly anyone does. There are 3 quarts of dirty oil in the HPOP/HEUI system that
blacken the fresh oil change if this isn't done.
Diesel Superdutys with high miles have another common problem with in tank fuel filter
screens clogged and pickup fitting break off.
Dropping the tank is the only way to fix this with the appropriate parts.
Non-start condition or running out of fuel condition is symptom of that problem.
Over the years I have learned to put a "First Aid Kit' in the truck of the most common things
to carry with me than can go wrong on a long trip.
Hoses, Belt Tension Idler Pulley, Fuel Pump, CPS, IP Sensor, EBP Sensor, Under the Valve Cover
Injector Harness and a few other parts and pieces.
