Diesels???
Discussion in 'F-250 and F-350 General Tech and Info' started by deboer03150, Jan 22, 2012.
  1. Roush PSD Interceptor
    My uncle has worked for Cummins for 39 years.
    I told him I bought a F250 PSD back in 2002.
    Couple of years later I went to see him and he asked me what kind of diesel it was again.
    I told him again "Ford", adding "a Navistar International T444E", he said:
    "The Lord will forgive you." :jester:
  2. Bdons-SD
    Someone told me I should have bought a cummins, I told them "but then Id have to tell people I have a cummins... "
  3. deboer03150
    deboer03150 Banned
    Archer, IA (Northwest, IA)
    Well its not my fault you guys push me away!!! And ifvi do get a new truck Ima keep this one too.
  4. Bdons-SD
    All trucks have their fair share of issues.
  5. deboer03150
    deboer03150 Banned
    True. You guys got any problems with the 5.9???
  6. c418
    c418 Full Access Member
    sure. here's the paraphrased version i can go more in depth if wanted.
    the absolute number one issue is the stock lift pump failure because it's not designed to work in this application- this is a common reason for injection pump failure, an aftermarket pump solves this.
    other things that don't matter as much are:
    -the exhaust manifold is prone to cracking because of expansion/contraction as a one piece cast design an aftermarket multi-piece solves this issue.
    -the vacuum pump to power steering pump gasket often should be replaced as it will leak oil and coat the driver underside of the truck (the crank case breather tube adds to this mess)
    -many the 53 series of blocks were cast incorrectly, people often say to stay away from them, but less than 1% of them really crack and if a truck has more than 60k miles chances are slim to none it will crack.
    -and of course the front suspension/steering on these truck is just stupid
    that being said, my truck is great, so are 7.3's and 6.0's, they all have quirks, but as long as you know what you're dealing with you'll have it easy.
  7. ak_cowboy
    Should done this....
    FordCummins.com: '99+ Ford SuperDuty Overview
    Fummins ftmfw :rocking:
  8. agjake11
    agjake11 Suck my tailpipe
    Rosenberg/Baytown TX
    Diesels are completely different to own and are just expensive. Gotta pay to play and just have to look at the big picture. Sack up and get one already or sticknto gas :ROFLJest:
  9. Roush PSD Interceptor
    ^ Well said Jake.
  10. Smigjo
    Smigjo Full Access Member
    Kentucky
    Hey, not sure if this has been mentioned because I don't have time to read the whole thread, but not all 53 blocks are bad. Brazil and Mexico made them, and as far as I could find, the Mexican 53's were good blocks, but the Brazil ones had thinner walls around the water jackets.
