Differential leak
Turkey Hunter
Full Access Member
Lebanon Virginia
Well I noticed my differentials leakin today. Does anyone know of a website wher I can order a gasket for around the cover. I'd rather not use silicone. Thanks
You can also use the orange RTV gasket. Really good stuff. I use it on my wheeling rigs...
Well ill probably just put a silicone gasket on tomorrow since I have almost a whole tube in my garage. And I'm just gonna reuse the fluid because its only been in there a year and a half.
i would just use silicone.. make sure theres no cantanamints in your oil... if oil is leaking out ... other stuff can leak in..... i would go ahead and replace it.. just my 2 cents
Re-using the oil? You're saving what, $25 bucks? And you are supposed to change your Rear end every 15k.
Engine = 5k ($30)
Rear Diff = 15k ($45)
Trans = 25k ($80-120)
These routine maintenance intervals will make for a long lasting powertrain.
