Did you read back about danger of running without condenser? @rmsawyer73 Sent from my SM-G930P using Tapatalk
No I haven't run it yet I'll just clean it up and attach a grounding wire to it. I would like to get a new one of possible I looked on autozones website and these came up and they look the same but when I enter my truck info it says it doesn't fit any idea were I can get one from? Sent from my XT1585 using Tapatalk
You have Napa in northeast? Maybe RockAuto? NVMD RockAuto doesn't have them. Sent from my SM-G930P using Tapatalk
That Duralast one can be adapted, cut orange wire brass off, butt splice into your black, slip ground cap ring on and ground with screw or machine bolt. Sent from my SM-G930P using Tapatalk
How was old condenser attached to negative of coil? Was it like half moon plastic clip connecting both positive and negative? Sent from my SM-G930P using Tapatalk
I was hoping I could do that and the only reason it wouldn't fit is cause of the plug end on it which I can easily change. I'm just going to do that then. There both duralast do you think I should get the 1st or 2nd one cause they have different part #s and I'm not sure what the difference is it just looks like the grounding strap is different.
