Dreaded MISFIRE!!!
Discussion in 'Engine & Performance' started by Venomized, Oct 11, 2012.
  1. Venomized
    Venomized Full Access Member
    A little history here:
    1998 f150 reg cab short box XLT
    4.6L/auto
    Coil packs not COPs
    Bought the truck about a year ago for cheap. Needed tires, rear wheel bearings/seals, had a misfire. Started slow and easy with the wheel seals and bearings. Once that was done I put new plugs and wires in. Then new tires. Also did fuel filter as well for good measure.
    After ~ a month or so the misfire came back. This time in full force. I went to vatozine and had the codes ran. i got 2 misfires #4 and #7 along with an EGR code (i cleaned out the EGR after) and rear O2. I swapped wires for new, plugs for new, and coil packs for new to no avail. This weekend im gonna try cleaning out the motor with seafoam and do a comp test. If that has no effect i will do a borescope (if someone i know has one) to see if anything down where i cant see is bad.
    Any other ideas??
    Im actually very mechanically inclined and have worked in the field. Just trying to get advice since we all know this is a common issue.
    Going to add this so everyone knows the sypmtoms:
    Rough idle
    No power on take off
    Misfire codes
    Thing i have done:
    New plugs TWICE
    New wires TWICE
    New coil packs
    New injectors
    Tested power to injectors and everythings good
    Seafoam
    Higher octane gas
  2. iowaredneck
    Try seafoam and could have bad cop or plug
  3. cowboy
    not a bad idea I'd swap your cop around and see if the problem follows.
  4. Venomized
    Edited the original post sorry lol. That info might help
  5. AKBray907
    Guarantee it's a COP, had this happen before. Easy fix an they wear out, not super cheap though.
  6. AKBray907
    Just a heads up incase you hadn't heard before a cop is coil on plug , it's the ignition coil for each cylinder. Just incase you hadn't heard that term before
  7. Venomized
    Ive heard it belive me. This truck has the coil packs not COPs and after changing coil packs it didnt help any.
  8. AKBray907
    I just realize you had a 4.6. Which plugs did you use
  9. AKBray907
    Post a video of whats happening
  10. Venomized
    I used NGK plugs (ive used them on all my vehicles). As far as a vid, im at work but will shoot and post one tomorrow.
