e fan help
Discussion in 'Engine & Performance' started by 2wd supercrew mudder, Jul 31, 2011.
  1. 2wd supercrew mudder
    2wd supercrew mudder Full Access Member
    texas
    ok so i bought two fans from orileys to replace my loud ass fan clutch awhile back. Well now i over heat in this texas heat with my ac on so what i want to know is whats a good complete efan setup for a good price.
  2. TxFx04
    troyer E fans is the way to go, that's what i'll be getting. E fans for your truck would be about $425
  3. supercrewzn
    I'm running dodge intrepid fans. They are a dual fan dual speed setup. I use 2 relays. One relay controls the low speed and runs with ac. The other relay controls high speed and runs from the thermostat. I got the thermostat and relays from advance auto.
    My entire setup was less than a hundred bux. I have 0 heating issues. In 100 degree weather at idle, my truck will not got over 194 degrees and ac blows 50 degrees.
  4. 2wd supercrew mudder
    texas
    well what i dont under stand is why my fans arnt putting out enough air flow to have ac
  5. 07Fx2
    07Fx2 Full Access Member
    Oklahoma
    How big are the fans? How efficient are they? These trucks need to stay in the 190-200 area. That's the tempature these motors operate best. I'm def going with troyers fans but reason I'm going with them is cause I'm going to do alot more to my truck. But your first mistake was buying from o ****yourselfs.
  6. J.Wal
    I did troyer fans, no problems with them, Eric installed them. He can give some info on them.
    J.Wal
  7. 07Fx2
    Oklahoma
    HellZ yea James.
  8. 2wd supercrew mudder
    texas
    well i don't really want to spend 400 dollars. looking for something a little cheaper cause right now i have dual 16 inch fans just hooked up to a switch and a relay and it stays cool as long as im moving and no ac
  9. rrogers
    you can find a cheaper setup. you need dual speed fans like thomas stated already. go to a junk yard and find a setup like his and properly hook them up.
  10. 2wd supercrew mudder
    texas
    na i got the money guess im just gonna go with troyer for the complete kit
