I had a v7 it started leaking compression thru the plug causing the wire to pop off Sent from my bad ass phone
I'm running dodge intrepid fans. They are a dual fan dual speed setup. I use 2 relays. One relay controls the low speed and runs with ac. The other relay controls high speed and runs from the thermostat. I got the thermostat and relays from advance auto. My entire setup was less than a hundred bux. I have 0 heating issues. In 100 degree weather at idle, my truck will not got over 194 degrees and ac blows 50 degrees.
