Engine rattle
Discussion in 'Engine & Performance' started by TxFx04, Dec 28, 2013.
  1. Roush PSD Interceptor
  2. TxFx04
    messed the link up but it's fixed now
  3. Roush PSD Interceptor
    Videyo working.
    yep tickity tick tick tick.
    Sounds very valve train related to me.
  4. Roush PSD Interceptor
    Read some more on this sound, some say it's the VCT solenoids,
    read some say it's the chain tensioners leaking down.
    The two different seals 3L3Z-6C535-AA has an offset design.
    the 7L1Z-6C535-AA has a straight thru design.
    Guess you won't know till ya look at it?
  5. TxFx04
    looks offset to me? :shrug:
    has the part number stamped right on the seal, imagine that. first one it is.
    I still need to know if this will fix the rattle for sure or if it's something else.
  6. ak_cowboy
    It should quiet down the ticking at the very least. Won't know if that's what is causing the rattle or not until you replace them. At least the 04-06 are easy. 07-08 require you to take the valve cover off....:facepalm:
  7. TxFx04
    I figure I might as well replace them right? Since I have the old design
  8. ak_cowboy
    I would, its super easy and should make things queiter
