Explorer help
Discussion in 'Explorers - Expeditions - Excursions - Broncos -Es' started by Sl33p3r, Dec 16, 2011.
  1. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    Can someone help me out and find valve cover torque specs for a 02 explorer it has the v6 in it I believe. My aunt has 2 kids and can't run the heat without smelling oil.
    Sent from my bad ass phone
  2. iowaredneck
  3. Bogger8658
    Bogger8658 Full Access Member
    Millington TN
    ^ it has a 4.0l SOHC not a 2.9 the torque specs should be like 12lbs
  4. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    Thanks guys. Y'all got any tips on installing em? Last time I did one was on my old s10 4cyl and I couldn't keep the holes lined up or gasket.
  5. supercrewzn
    They should be rubber and the valve cover will have a grove for the gasket to sit in. If they are cork, spread a little grease on the valve cover then put the gasket on. The grease will hold the gasket.
  6. Bogger8658
    Millington TN
    they are a rubber gaskit that clips to the bottom of the valve cover as far as tips go make sure to keep the plug wires clear i pinched one under the cover on my mom exploder and it caused a oil fire the the leaking oil
  7. Sl33p3r
    Sl33p3r Banned
    High Springs, FL
    I had a cork one on my s10 they are a pain but the set I'll get for hers is rubber. I might do it this weekend. The shop wanted $500 for it the parts are just $20
    Sent from my iFord f150
